hi guys can you hear your after market dump valve /bov when you just revving the engine I cant hear any thing from my blitz valve just wondered if that's normal also if I rev the engine between 3000-4000 rpm I get pop n bang sound from the driver side exhaust only is that a misfire or sum thing on driver of engine .
  • Replies 52
  • Views 6.1k
did you pop bang start after fitting the valve or was it there before
You'll get very little at a stand still mate as the zed doesn't come straight on boost. Go for a drive and stick your foot down lol. What kind of BOVs are they and where are they fitted?
Membership No 0780
INSURANCE GOOFA
The nicest sound they make is when they hit the bottom of the wheelie bin! :wack: :rofl: ;)
Is it me....... or are they on the wrong pipes?
[ATTACH=CONFIG]94483[/ATTACH]
No, I don't think it's you; your picture is the normal set up. I have seen them in some strange places before though.
this is phutumsch engine bay pic lets hope he can shed some light on the matter bov 3.jpg
[ATTACH=CONFIG]94485[/ATTACH][ATTACH=CONFIG]94486[/ATTACH]
Hmmmm the plot thickens...... anyone got BOV's fitted and where??
mine are fitted were the stock ones are
My interpretation is that they are just releasing pressure, so as long as you put them between the turbos and the plenum, then you're good.
Yeah it's the same loop, what pipe they are on is immaterial. As long as it's between the turbo outlet and throttle body.
blitz [ATTACH=CONFIG]94482[/ATTACH]
Your radiator will do its job 100% better with a fan shroud btw.
Ideal/ most efficient place is as close to the throttle bodies as possible,
If you think as the throttle closes the pressure is released through the dump valve, if the valve is further down the pipe what direction is the air now flowing? The wrong way lol
If there is one car that should never have BOVs fitted whilst still running the standard MAF and intake pipework setup, it is the 300ZX TT.
:bow:
after what noel says here am going to remove my ssqvs and fit my stock valves so the hks are now for sale
