Set a few up now. It's what I recommend after the Profec B Spec 2.
IMO, it's by far the best looking boost controller.
Regardless of what it looks like, would you say there any reliability or other benefits to go from a Greddy over a HKS EVC for example? In your experience, would you recommend the Profec B Spec 2 over the new Profec Noel?
They all do the same basic job when set up correctly. The only branded EBCs I suggest people stay away from are Gizzmo ones.
I like the GReddy brand in general. I also have a soft spot for the AVCR. It works well as a simple boost controller, but can do a lot more if required.
As far as New Profec vs Profec B Spec 2, I don't really have a preference, but I guess the Spec 2 wins because it was part of my 11s MR2 setup, and handled 34psi with aplomb!
I've heard of them but never seen one personally.
Apart from the bad spelling on the box I think you can tell by the bad stickers used for likes of the serial
numbers and manufacturer label on the sender unit.
I'm fairly sure the one I have is genuine (touch wood) and the labels are a higher grade and the manufacturer
label on the sender is made out of metal which also looks genuine.
Have you ever heard of or seen fake GReddy Profec B spec 2s?
Just buy from a reputable source if you're worried about snides.
The only Profec B Spec 2 I have seen fail was new from eBay. The PCB had "TRUST" imprinted on it, but I didn't really check for any other signs one way or another.
:crying:
I'm struggling to find suppliers of new Profec B spec 2 controllers from reputable sources due to the new Profec replacing it. I would prefer to have the Profec B as it will take up less space in the glove box! I've been in touch with GReddy to find out if there's a way I can confirm with them that an item I've bought is genuine or not. If there is a way I'll take a punt and confirm if it is (or isn't) an authentic product once I've bought it.
