help with door handle removal
so am stripping the car down ready for paint in 2 week. whats the best way to remove the door handles do I need to remove the glass and runner first ? looks tight in there all the door cards are off
is there just one nut or 2 holding the handle ? also is there any way to unplug the wiring as I need to remove the whole door ?
sound that's great will crack on again in the morning. is there a way to remove the devider on the roof that the t tops slip into to is that a case of removing the roof liner ?
Yeah, the roof liner has to come off. Although you can get away with just dropping it at the front. Sun visors, corner trims, rear view mirror, temp sensor/map light unit and the interior light will get you enough access to remove the nuts. From memory I think there's about 8.
will have a go the car is in bits now how it all goes back again am not sure as some of it was like 2 years ago its a total pain in the arse but must be do for a good paint job
