Youngest owner of a z32
- Replies 78
- Views 9.5k
- Created
- Last Reply
Alic 23 posts
Funkysi 12 posts
Pebkau 5 posts
tomomontana 4 posts
Hi the club,
I am 16 and i recently purchased a 300zx
and it will be my restoration project for a couple of years.
The car is 1990 automatic Twin Turbo targa top.
Good things:
- It only has 46,000 miles on the clock (74,000 km)
- I think it has barely 1000 miles on the automatic gearbox only recently replaced.
- It has MOT and drives well, gear changes are really smooth.
- coilovers with lowered suspension and a kakimoto titanium exhaust
- (apparently) really rare JDM from and back bumpers but missing the side skirts in the set (if someone could identify the bumpers that would be great so i could find the skirts for it
- aftermarket ECU (not sure what make)
- It has an aftermarket air filter
Bad points:
- When driving you can hear an air leak and the car will not boost properly. (the previous owner said that the oil pressure and boost gauge work when they wont to but i have never seen the dial move, boost pressure stays at just over 0 psi and wont move. he said that it has a defi gauge controller but has no gauges connected so i am guessing that the oil pressure and boost gauges have been cut and re-routed to the defi). There is a possibility that it will still boost but it is not noticeable enough as the acceleration is very linear.
Questions:
1. Does any one know of any good z specialist in/around London. I heard Z centre in Bristol is the place to go to, but its not really worth the trip at this stage.
2. Does anyone have an electronic boost controller they could sell which might fix the cars boosting problem. i have a blitz sequential boost controller but i am missing the solenoid and i have no idea if it works or not.
3. It has been recommended I replace the cam belt as I don't know if it has ever been replaced. Is there anything additional i should be thinking of replacing at the same time and where i should go. (I will get the boost looked at if I do not fix it)
4. Are all z32 turbos really quiet? i plan on upgrading to bailey dual dump valves which will help performance but also give the iconic turbo pressure release sound. should i hear the turbos spinning at high rpms or at lease a whu-tu-tu-tu when slamming the throttle shut or do i have to upgrade to really expensive turbos for that to work?
Now for the parts:
I heard somebody on the forum had a pair of rear speaker grills, could i get in contact with someone that does, Thanks.
Also if anybody is breaking a car does anyone have an engine cover as i do not have one. (the 'Nissan v6 3000' metal plate thing)
Finally does someone have a drivers side targa wind deflector, a little plastic bar that rises when you take the targas on it. my brother snapped it off (don't worry, i dealt with him).
Thanks and hi everyone, I'm Ali
Oh, and the video of the bumpers and tour is:
