350z front Brembos
Hi all, as previously mentioned im looking at upgrading my front calipers & discs, having searched through previous posts can someone pls confirm if 350z front brembos are direct fitment/replacement with 324mm discs or if brackets are required? Seems to be mixed views, i know the rears are a big to fit and require brackets & alot of pissing about.
Thoughts?
James
I'm sure the holes in the hubs have to be drilled out a bit,
The 2 bolts that hold caliper on are a bigger size on 350z they go through hub into caliper,
So you'd ideally want bolts with caliper...
should be fairly easy to drill out on the car....
What terry said, they use a bigger bolt. Other than that's they are pretty straight forward from all accounts. The adapter brackets are generally to enable you to use 350z discs with stock calipers. Or to utilise the massive calipers found on evo's and various other things.
