MOT - First in three years.
The rebuild is complete and its MOT time.
Driving to the garage that done the respray at about 8AM tomorrow for a quick check over
then they will take it to the MOT station for a 1:30PM test.
Nervous as hell about it so hope all goes well.
The only issue I can foresee is that its a 1996 and I decatted it but I'll just say it was a 1992
and it was imported in 1996 or something.
  • Replies 65
  • Views 5.3k
Good luck, fella! Hope she does you proud :thumbup1:
Bloody hell! What do they think's wrong with it?
Now they are saying that they saw blue smoke but its been white when i drove it.
Other things were a few brake hoses were lose but i expected that as i just changed them over, thats now tightened.
Heres the list when they phoned, most easily fixed apart from the engine knocking.
-- Offside near wheel bearing has play on it
-- Near side rear wheel bearing has play on it
-- Near side front top wishbone has exesive play.
-- Exhuast centre section is insecure - hangers missing
-- Drivers side - side repeaters not working - (was working last night)
Send him a text, he'll get back to you later. He's pretty much on his own at the garage at the mo
ok,
So the end of it is my zed for the 3rd year running now won't make it to JAE.
The smaller issues I likely can get resolved fairly quickly but the engine is another story.
The plan now is to trailer it from Troon to Shrewsbury which is about a 4.5 hour trip give or take.
So i'm now after any contacts who have a trailer that I can move the zed.
I have one from the local garage but I think I need a special license to use it which I don't have.
So if anyone know of somebody available with a low loader let me know.
Most of the issues don't seem too bad
The front upper wishbone is so think that I believe can be got around with a letter as it is part of the design, so I have heard
The last two can be sorted.
The rear wheel bearing is not a bad fix, just have to get hold of one.
The engine is probably a setup issue, have you boost leak tested it, is the timing correct (auto conversion), are your pcvs ok. I'm sure it's something small
I've been through lots of little teething problems with mine, you will get there in the end. Chin up
