Problems still there
Ok well I have had a brand new engine harness put on. Sorted a lot of problems out but the rough idle is still there. Absolutely fine when driving but at idle the drivers side exhaust seems to stumble a lot more than the passenger side.
Also at cold start the drivers side is smoking a bit (white).
Any ideas now?
I have:
Changed maf
New electrical harness
Egr bypass
Water bypass.
New injectors
I tried to do a compression test but I couldn't do it aha. I'm pants.
I did a smoke test which showed smoke was coming out of the drivers side recirculation valve. Also on the Stoke boost gauge the needle is a bit further away from the left "7"
anyone near you got conzult or datacan and willing to help.
dan :yes:
Well. Took it to mike at outlaw customs and he had a listen. Laughed. Then said don't worry. It's the crank angle sensor. There's like 500 holes and some will be clogged up. That's what that small miss is. He told me not to worry about it. It's common.
