number plate lights
not sure if anybody has changed or modified theirs, but it seems these are no longer available from nissan, my car has failed the mot on a number plate light not working, and on inspection today one of the terminals inside the light has broken off. anybody else had to change them for a different type? i really want to keep to stock looking, maybe a LED version. my car is jap import if it makes a difference
They're the same as what's used on the back of a k11 micra if that helps. Mine had the same issue with the snapped terminal on one bulb.
that's definately an idea, i'm going to fit new ones for now to get mot sorted then will modify with leds at a later date
That's a harsh MOT tester, failing it on just one number plate bulb. I know technically correct, but still harsh!
i had a couple of other issues as well, horn wasn't working, slight exhaust blow and brake servo leaking air, servo was the same last year and he passed it, horn was the relay had stuck open, i'm getting stanless exhaust front pipes made tomorrow
