Swb na prop confusion
Hi guys been doing my na subframe swap over the weekend . I'm sure I was told I only need the rear section from a na but this won't fit to the front of my tt silcktop . This prop was from a auto car is there a diffrence . I'm confused do I need a swb na manual complete prop of just the back section from na swb but a manual one thanks .
TT and NA flanges are different where they bolt at centre bearing, but flanges are interchangeable on the splines so swap your flanges to match.
I'm running a TT manual front prop bolted to NA auto rear prop, had to bolt flange from the auto NA front section to the tt manual front section so it matched the auto NA rear section.
Ok thanks I have 2x2 rear na prop section which is too long so I need a swb na rear prop and then change the flange where it bolts to the tt front section is this correct . It's just finding a na swb prop is the problem .
Yes good idea where do I get a one piece prop from .
