Santa`s clearly been a naughty boy and the spirit of christmas zeds has decided to take away his power steering.
It`s been displaying symptoms for awhile, mainly being a little stiff first thing (steady now) but being ok when warmer.
The hicas light came on the other night along with a drop in assistance.
I did the usual and checked the levels. Seems ok but my float is worn and it`s always a guess. So i used a probe and measured this against the guage. All good. Still the same result so It`s not that.
So, as i drive off all is good then after 10-20 secs or over say 15mph the steering gets heavier but not totally gone, then shortly after that the hicas light to bring my attention to a fault. Looking at the manual it states that this occurs if the ecu is not getting a signal relevant to the cars speed so goes into a failsafe sort of mode and stops the hicas. This also keeps the steering at motorway speed assistance levels.
The temperature thing makes me think it`s an electrical connection issue. I`m aware the signal path comes from the gearbox thru the speedo head to the hicas ecu and then that gives the relevant signal to the solenoid etc. Now my speedo reads fine (but it could be the pass thru connection on the board). That rules out the gearbox speed sensor. Next is this pass thru connection. Does anybody know which wire it is?
The fact that the steering still has some form of assistance and points in this direction but it`s hard to find any information on which components or sensors cause which symptoms apart from that which i`ve already stated.
Hello alll,
Anybody?
