My 300zxTT starts up pretty bad, turns over fine but misfires until properly warmed up, if i give any throttle, when i let off the revs will die down and then cut out. if i try to pull off it will usually stall, and the turbos wont kick in until properly warm. any suggestions on how to smooth this out or if its a symptom of some issue.
I'm also looking for seal kits for my turbos as both are leaking and causing some pretty crazy smoke, its a jap import so im assuming it has the bigger jap turbos and i haven't had much luck searching for them, if anyone knows where i can find them.
Whats up
Thankyou.
