replace/modified turbo intake pipes
has anyone replaced these horrible black plastic pipes with a custom set up or something you can buy pics and links would be great thanks.
dan.:thumbup1:
I run with no intake pipes. It's pretty swish :laugh:
arrived and over the moon great quality as you would expect from Z1 and look fantastic much better than those horrible black jelly pipes thanks to Funkysi for steering me in the right direction
dan. :)
They're going to sound nice, the accordion section in the OEM pipes is there to muffle the sound of the turbos.
Edited by Noz
I'm planning on running some hard pipes with a joiner or two straight from the tub to the headlight for dual intakes. I'm guessing a hard pipe will be even louder?
Yes, hard pipes offer even less sound-deadening qualities.
will let you know at the weekend!
dan.:)
look great but once fitted the PCV pipes just dont reach on pass side and way out on drivers side think may need to do some more pipework.
dan.
I still have an OE pair by my desk, we did consider doing these in silicone but depends on numbers? We could offer the option of bigger inlet ends for bigger tubs to.
my plan is to get some hose with a 14mm ID and take the valve and brush out of the old pcv hose and put inside the replacement hose which i can cut to length.
dan.:thumbup1:
