Vac - air pipe
Hi can anyone tell me if this is meant to be connected to something? Looked around but can't find where it goes drivers side next to brake fluid pot jerezase.jpg
Need a pic further away or relative to the position where it is coming from
EGR and AIV solenoids are in that corner from factory iirc, it could be one of those two not deleted properly. Before you go crazy, try to trace what the other end goes to, I bet it either goes down the back of the block or into a hard pipe on the drivers side of the plenum.
Looks like the AIV and EGR solenoids are still in situe. Do your boost gauge work?
iff its sucking then screw a 6mm bolt down its neck to seal it up for now...could also be giving a boost leak untill you find its reason to be living:)
Hiya yes boost gauge works thank you all for your help and advice :)
