Gearbox / Alternator Loom Identification
ok, ive checked again today and my oil pressure sender is at the passenger side,
now I have aftermarket sender in there for my drift gauges so looking to add a oem sender
on the oil branch at the drivers side, there is what looks like a bolt that unscrews so could
I put the oem sender in there like where it is on other zeds.
I looking to keep the oem guage working aswell as my aftermarket digital gauge as dead needle bug me.
Hope this helps you out judging from your first picture I can make out the PTU
This is a pic from my UK TT before it got picked up to be scrapped
The 2 in the middle look like there for the alternator,
Then oil pressure sender,
Then looks like starter wire,
Then neutral, reverse and speed sensor,
The rest plug in by the drivers headlamp...
The round dust boot has a yellow plug under and is the stock oil pressure sender which is on passenger side of block.
I thought the stock pressure sender came out the big relay/fuse box in the engine bay...
1 yellow wire,
The alternaror has a plug, and another wire that bolts to it, which i thought would be that wire with dust cover...
The oil pressure sender i think is that side on American cars so maybe thats why its there...on that loom.
but your stock oil sender will come from the big fuse box wiring loom...
so maybe just leave the new plug unplugged...
Edited by Terry
