SOLD JDM 300zx manual TT with high HP mechanical mods £2500
- Replies 33
- Views 1.6k
- Created
- Last Reply
Medallion Man 14 posts
Gaz 300 3 posts
Lexx 3 posts
jayden 3 posts
Originally a 1991 tt auto but nearly all mechanical components changed for newer... its worth the money for the engine, box & shaft alone.
Car Taxed to 1st Oct and MOT’d till 6th June 15.
I just can’t bring myself to keep going, unfortunately (to my regret) I didn’t replace the turbos at rebuild.
As far as I’m concerned the body needs a lot of work to get it up to anything other than shed.
The current engine was re-built at Zedworld in 2012.
This engine is capable of well over 600bhp…
Engine bought as a short block (USA import, build for racing):
Wiseco forged pistons (88mm)
Forged Eagle rods.
Balanced main shaft, block was machined, honed & cleaned.
New OEM bearings, crank, oil pump, oil pan and rear main seal (June 2012)
Also:
Cometic metal head gaskets.
Nismo 555 injectors
PTU (brand new for USA 2011)
New water pump (2012)
New cambelt (Nov 2012 - Zedworld)
full Unorthodox lightened racing pulley set.
JWT 530bb turbos (blowing oil, seals gone)
Chipped ecu
Greddy PRofec e-01 boost controller
Jap speed decat pipes
Custom stainless exhaust
HKS twin dump-valves with Y pipes.
induction hard pipe kit - silicone (green)
Godspeed side mount intercoolers
New wiring harness (2008)
Alloy hi-flow radiator
K & N cone air filter (cleanable)
5 speed manual gearbox (out of a 1994)
6 puck competition clutch.
lightened balanced flywheel.
Single piece prop shaft (Zedworld)
R33 front disks and callipers
Alloy hubcentric spacers
18" alloy wheels (need attention)
Whiteline anti roll bar
Hicas eliminator system - (Conceptua - Bycas in green)
EGR bypass (removal)
Water plenum bypass
Cruise control deleted
Clifford concept 650 alarm system
Greddy front bumper
Viper rear spoiler
99 spec front light inserts with HIDs
Rear fogs integrated into rear center light section (all LED).
clear front & read side repeaters (yellow leds)
Dash 3 gauge pod (with Tim gauges, all led) yes I know Tim is crap but they look retro..
if you’re interested I’m open to offers. I’ve just been offered £2k by a guy on ebay but I’d be gutted to let it go for that… If there was any way I could afford to keep it (even for a track car) I would…
more info available if interested.
Edited by Steams
Updating Status
