upper plenum gasket advice tips plz
Hi i'll be replacing my upper plenum gasket this weekend, any tips?
Yeah delete loads of junk in the process, replace the pcvs and hoses in the process. The hoses and cables etc will be brittle so be very carefull and gentle, replace what you can.
screw two 9" lenghts of 8mm stud bar in front and rear corner of the lower plenum....stops the gasket moving and you can just lower the plenum over the stud bar knowning your blob on for the bolts. Fit 2 plenum bolts and then just un-screw the stud out.:wink:
Top advice!
All done today and she runs perfect:thumbup:
