I have a bit if whining from gearbox when in neutral and clutch 'not pressed' (de-pressed), which gets better when warm (then you cannot hear that much of it). It has been there for years, and not really got much worse, but I am going to swap Clutch in coming weeks, and tempted to see if I could change the 'Input shaft bearing' without too much work when it is out of car.
Know that 'slight whine' may be from other bearings on main shaft, but suspect that input bearing is the most likely.
Can you swap the input shaft bearing without splitting the whole box? What I look to determine is if it can be done by taking the front cover plate off (which will be taken off to replace front seal anyway).
