How do I remove the rear seat?
The bench, you pull up from the front edge of the squab. It's clipped in via compression clips. The back just has locator rails on it and it pulls straight out. Seat back is secured by 2 12mm nuts either side, hidden behind the boot carpet (which is clipped to the seat back). Undo those, pop out the carpet from the rear facing section and the seat should come out.
It's not much extra effort while your there to pop out the rear cards and veiw into the sills, get some anti corrosion product down there :)
Si there 2x10mm bolts either side lol...Need that address too...
As Terry said 4 x 10mm bolts, you need a refresher course Si :lol:
Jeff
Well the heads are 10mm and need a 10mm socket/spanner to work on. However the bolts are actually 6mm with a thread pitch of 1.25 :tongue:
Thanks guys, it was the bench that was puzzling me, I had tried to pull it up at the front but wasnt sure I was doing the right thing. I'll try not to distort it but it aint goin back in, the interior is coming out as I'm going to use it for sprint days.
Steve
