my ams over flow tank
as some of you have seen my thread about removing the overflow bottle and windscreen bootle from behind the intercooler well I have just got the over flow tank its very light just need a washer bottle now and a smaller battery here are a few pics for the z geeks out there
it will just need a smaller bat
I know, I was being sarcastic. AMS fitment isn't best known...for its fitment. ;) Hope it goes on OK. You could put the battery in the boot area and put the PAS reservoir up where the battery was.
or put the battery in the boot and fit the window screen washer bottle next to the new over flow tank .if I was fitting the battery in the boot what the best was of getting cable to the boot throw the car or under the car am not very up on wiring
You can get it through the car. There's a large grommet at the bottom of the wheel well (behind the splash guard. You can run the cables along either the sill or alongside the transmission tunnel.
sounds like a plan just looking to find some kind of battery straps to hold the bat in the boot
what amp battery wire should I use ?
It seems *a lot* of work (and cost) for minimal gain to me. If you must do away with the stock overflow why not go this route?
If you have removed the carbon canister there is this much room left, even with the stock overflow in place.
Edited by AndrewG
want the battery moved any how to make room for washer bottle to
It's supposed to fit beside the battery without removal. The idea was that it is a header tank aswel as the zed doesn't have one. Where did you buy it from mate obv states, but z1 or ams directly.
ams but my batt is far to big and take up all the room
That tank looks no good as its a sealed top...you would need to somehow vent it so theres no positive pressure building up inside it from under bonnet heat as this would stop the venting of rad water getting in
was going to fit small rubber pipe coming from the cap so if it got to full it could run off
