There are a host of problems to solve with this car and don't know the best way of going about it.
Is there a specialist I could see who can solve the following issues at a reasonable price? If so, how much would it be?
The following problems:
- Hicas leak ... I need to top up the reservoir with ATF Castrol Dextron II every 2 weeks or a red warning light comes on (pipe replacement? Seals?).
- There is blue smoke coming from what I can only think of as oil drenched / old spark plugs... (Old old sad spark plugs). The boost for turbos are good though.
- There is a highly annoying creaking noise coming from the passenger side dash (and I do mean annoying).
- The clutch is also slipping in 4th & 5th gear - mainly due to the car being off the road since 2008.
All these issues were caused by a blown ECU... probably from a chewed up wiring loom and a nest found in the engine bay. This has put the car off the road since 2008, turning it from something perfect into a relentless money pit. I'm assuming from the evidence that a rodent caused all these problems before being blasted out at some point...
If anyone could direct me to a good expert in Zs, that would be much appreciated.
Hello, I am new here.
I own a swb manual with a Vg30DETT...
