99 spec bumper fog lights or scoops?
when I fit my 99 spec bumper what looks best fog lights of the scoops you can buy to replace them what do you think
  • Replies 26
  • Views 3.4k
Depends. If you have big SMICs, then yeah, scoops are best. If you have scabby fog lights, then go for it. If you have new fog lights, I'd say keep them.
New fog lights look very fresh and clean.
Hmmm - tricky.....
....Personally I prefer the look of the fog lights over the ducts. But if you really need the function of the ducts - like piping cool air to the brakes or, as Si says, big intercoolers, then function over appearance. But for appearance, then I reckon stick with the lights.
Richard:cool:
the issue I have a uk car the side lights and indicator are were the fog lights would be .so I will be fitting the side lights in the 99 spec indicator along with the indicator its self .I have no wiring for fog lights
In that case mate - I'd just leave things as they are. Clear out the orange in your UK spec indicators (as I have done) and pop them into the 99-spec where the fogs would go - then leave the 99-spec corners blank just like they are on a UK spec bumper....
....Unless you want to buy a pair of J-spec fogs and wire them in properly....:wink:
Richard:cool2:
Richard:cool2:
I see was going to mod the 99 spec indicators so side lights were in there. duno what to do yet
In that case do the modification - and buy some US spec fogs. They are cheaper than the J-spec ones (as they don't have built in side lights) and wire them in as proper fog lights!!
US Spec fog lights are actually identical, well, when I say identical, visually they are. It's actually only the reflector that's different. You only need the lens which comes with the reflector, the main plastic base unit from JDM lights can be used. My fog lights are US spec, but I removed the US reflector and refitted my JDM reflector. Stupidly, I threw away the US ones. I wished I hadn't as I'd quite like my side lights in my S2 indicators now! Doh!
so j spec are fogs and side light ? were is the fog light switch in the jap car I take it my uk don't have the switch so would have to fit on
Ducts for me
I like the duct to to cant make up my mind
The fog light switches in JDM and UK cars are in the same location. The icon is different on each though, so you'd have to fit an auxiliary switch so that you can operate them independently.
I see so in the jap car it turns the rears and front fog on and the uk car just the rear fog
A pic for inspiration :)
I do like the ducts . thinking about it how often do you ever use your fog I never used then on my car or van
were have you fitted your side lights
Five 5mm leds pic before respray
that looks good
Personally I prefer the Ducts. I find the fogs a bit dated looking.
Move the side lights to the indicator housing.
ok ducts it is does the 99 spec bumper bolt rite on is there any mods that need doing to fit it
No mods requared straight bolt on
Are they behind the lens? Any pics not illuminated?
Yes they are behind the lens
They do look nice, are they a custom job? any more info?
may want to have a blast at them myself :cool2:
Them indicators are for 99 spec bumper
