Did I seal my sump incorrectly?!
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I think I've sealed the actual sump itself fine, using heat resistant gasket sealant. I went all the way around, concentrating on the dimpled bits, and used a thin covering on the curved seal areas at each side.
However, I didn't use any sealant on the inner section of the plastic seals, as they fit into grooves on the bottom of the engine. There clearly hasn't been sealant used in the grooves previously.
Do you think it will be ok? Do I need to do it again?
I suppose the obvious thing to do is fill the engine with oil and see if it leaks, but that won't test it under preasure when the engine is running.
