Stock turbos rebuild
Can anyone tell me where I can do my turbos ? I got a rebuild kit but someone needs to rebuild and balance my turbos for me, any ideas where I can do and how much it will cost?
If you can stretch a bit more buy new. Rebuilds can be good but good rebuilds cost. For not much more you could have new ones.
I refurbed myself and sent shafts off for balancing. got the rebuild kit of eBay for about 50 each
I also got rebuild kits but I cant do it my self I nee some special tools to do it. How much is to send shafts for balance mate ?
think it was about 40 plus delivery, have a look at some how to guides on the net and see if you fancy a go, the cost of the tools will be cheaper than paying for the rebuilds.
I was reading on web about turbo rebuild and found interesting news. Sometimes if turbo got too much play inside and after rebuild kit installed its still can be some play because a shaft centre could be wear out.
What is your opinion because you done rebuild before ?
I did do both mine but can't comment as the engines still not got in the car yet. I suppose if your suspect about the condition of the turbo a rebuilder would probably closely inspect each part before assembling to ensure their guarantee.
The advantage of getting them built by a turbo company is they run them up to full speed and they should come back with a shaft ballance sheet and also detailing rpm and leak free info
and the warranty :) and you get window sticker :)
