- Replies 34
- Views 8.3k
- Created
- Last Reply
sky 10 posts
ruishy1 6 posts
hellraiser 5 posts
znut 4 posts
Here is my BBK !
Parts
Mitsubishi evo 5/9 Brembo calipers
Mitsubishi evo 5/9 brake lines
Mitsubishi evo 10 rotors 350x32mm
Adapters
The evo brembos are one of the best brakes available
They are 1.5kg lighter than the stock Z32 iron calipers and they are huge! pistons size is 2x40mm 2x46mm
The Z32 master cylinder is the same size of the evos so they are perfect to run these babys
If you want to keep low weight, you can purchase the 2pc Giro discs, they weight the same stock 280x30mm Z32 about 7.5kg, but since the calipers wieght less, you have bigger brakes and low weight!
Here is my set
Missing the rotors, they arrive next week (GiroDics 2pc rotors) :)
