manual box safety mode ?
is it some kind of safety feature on manual gear box ? i can`t get in first gear while car is moving ... only on full stop i can get it in first gear
Nope, should slot in, you have the OEM gearstick so its not a short shift problem, to me that sounds like the clutch needs adjusting like ive said before.
sounds like the Biting point is a little low and its keeping th gear box gears spinning ..
how do i do that ?
on the clutch pedal at the top there is an adjuster bolt .. u need to Lengthen it some more
how to ajust it ? :)
thanks :) will try it :)
yep agreed did this myself the other week also checked the fluid and did alittle bleed works better then ever now
if your moving why would you want to slot it into first ......poor valves !!! second on boost is plenty quick enough ..doing that you will spin it and end up wrapped round a tree
when parking :)
i had this once on a clutch set up ... i ended up just making a Longer Push rod for the slave cylinder .. by about 1/2" longer
Edited by MarkDerby
i had this once one a clutch set up ... i ended up just making a Longer Push rod for the slave cylinder .. by about 1/2" longer
i done the same on a nissan cabstar which ironicly has the identical slave as a zx
