guessing is now open !!
Ok here is the spec
PE1420 turbos,
Border front mount intercooler
forged rods Eagle
Forged pistons
Cometic Head gasket
555 nismo injectors
Accel race bearings
Mike smith manifolds
reworked heads and cams ( unknown )
custom exhaust
full under drive pulley set
Fidanza Lightened balanced flywheel
uprated alloy radiator
hard pipes
leader differential gear set
on its way on thursday to Turbo Noz for a boost increase and re map
what do you reckon are the BHP and Tourque figures
winner closest gets some Rep and something nice in the post
get your thinking caps on guys and girls
Kaza :punk:
  • Replies 125
  • Views 6.3k
you stingy lot! if you have true twin air filters and the exhaust is at least 2.5" all the way through you should see over 550bhp at the fly. PE1420 have quite a punch
cant believe the sub 500bhp guesses, im not running close to those turbos and im getting 424.6bhp, also have a dyno showing that it pushed 457bhp at one point, i got 555 injectors, but have GT525 turbos.
With those engine internals, plus turbos, with a good map, there is no doubt he should be looking around the 550bhp mark.
560 fwbhp:ninja:
i dont disagree about the tubs .. but the injectors are 555 .. and thats the limiting factor of about 550hp as this will be kinda at Max duty ..
so for it to run safely around the 500hp mark would be good
well we will see what mr Noz ( Noel ) has to say when he dynos it and i can eventualy use it as i intended....
i am hoping for a useable 450 wbhp and around 490 ft/lbs ........anything more is a bonus anyway i will see what ive got zed related in the garage to post onto the lucky winner
some good gueses there by the way fellas....i will post up the dyno sheet when its done ...
cheerz
steve
agreed with mark 90% is safe limit so at 45psi so mark is spot on with 500 being max at that fuel pressure
As is the MAF, If running a standard MAF and single cone it's also limited to around the 500 area, hence Jaffa's comment above, running a dual or even MAP sensor could see more gains.
smithy
Im sticking with my prediction as a safe useable power output, maybe a little higher on the torque but will leave as I oredicted
Hope all goes well steve, will look forward to the dyno sheet
561 fwhp, 550 ft lb as max power not necessarily what you leave it at.
I hope it's a good result for you I just found out my tubs are the same as PE1420's.
You have the benefit of free flowing heads as well........
