Engine Build Take 2 Plus CPZ Order
Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 13k
3 attempts to fit the engine due to the larger tubs and down pipes being very large :)
Edited by MarkDerby
Looks so much better with a fresh lick of paint in the bay, looking forward to the mapping, think your going to be happy with the power hyke and responsiveness with all that gear.
Alternator and PS Pump Fitted ..
Made some Intake piping to replace the old bellows pipes
with pipes ... lol
no really ... Left side front loops around to the back right rear tube . then same tube out but on the side to the tank ..
then Right front direct to tank
take a look at Post 185
How did you fix the grills to the bumper Mark? I was thinking of getting a hot glue as mine is currently bolted through the bumper and looks shite
Silicone sealant m8 .. . for the amount u need to use
hot glue would do it but u will use quit a lot of glue sticks i'm sure
DONT use hot glue, its very bad for grills fitting. Use silicone as Mark said.
Done a few more things the other day
Nearly there then..... like your bonnet struts, where were they from?
yes m8 when i go on to my emerald ecu there will be no maf's and dual pop setup
but for now of the running in the single filter/maf will be just fine
  • 3 weeks later...
Latest video of the engine bay and Running
[video=youtube_share;wv4yhc2b5GA]
