Engine Build Take 2 Plus CPZ Order
Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 13.5k
Hi Mark, I am about to embark on a similar build but I am dreading the piston ring gapping process. How easy/difficult is it to ensure that the ring ends remain square after grinding? Is a dremel tool up to the job? Anyways great build this is and I will be following this one for sure. Keep em pics coming. :thumbup1:
Gapping piston rings is quit an easy job .. just very time consuming as u have to check it at least 6+ times on each ring to get the right size gap
as for keeping the ends square u only do one side and u have the other to compare against to keep it straight
and the dremmel will do the job just fine thats what i used .. with a Fine grinding disc end just take your time ...
Had to get some New heads machined up
due to an Incorrect Skimming Profile on one of them
so just stripping new ones down so i can start to Port and Polish them Again :(
Edited by MarkDerby
Mark can you explain more about what you're doing when you gap the piston rings? What thickness feeler gauge do you use? Is it the same process for all the rings, im presuming there are three per piston?
ok its a little complex as the Gap for Piston rings change from Top to 2nd plus on the bore size ... but here gos
Will take a Typical 88mm Wiseco Piston
they have some Gap recomended size and its all done in Thou Inch
For Turbo applications its
.0050 top Ring
.0055 2nd Ring
Now you have to Multi ply that by the bore Size in Inch
88mm = 3.46" x .0050 = .0173 or ( .4394mm ) This is your Top Piston Ring Gap
88mm = 3.46" x .0055 = .0190 or ( .4833mm ) This is your 2nd Piston Ring Gap
the Oil Rings are Pre set size and do not need gapping
Hope you kinda understand
How long did it take you to grind all that out then mark? Have you just taken it to the boundary of the gasket? I believe the exhaust side should be super smooth and the intake can be left rough as it aids mixture iirc.
both can not be to smooth .. as this will not agitated the flow and hinder the flow its self ...
Exhaust ports have been opened up 5.5mm width/hight to match the headers Leaving 1mm down step
Most of today to do one Head .. i need to take other pics as cam dosnt really show it all
Oh right that's not too bad all things considered. Its boring and time consuming work aint it. You still on stock cams with this build?
Check Page 5 post 99 out
full list on pics ... but yeah BDE after market pulleys
I think you have a good point there z32bolt. As I understand it, if you polish the inlet too smooth, you get a condition known as wetting, this is where the fuel separates from the mix and clings to the smooth surface of the ports.
Seem to recall reading it somewhere.
yep .. your right ... the porting isnt ultra smooth polished .. it still has a texture to it
That looks like a piece of art. I'm not mad on massive power chases as you can only use so much on the road, but geez that looks sweet, such a shame you will never see it :(
not sure really
but the tubs/injectors/crank/pistons/cams/ and other bits are good for 800+ on paper and Specs
all depends on how its tuned i guess so anything more than 300hp would be great :)
Don't be so soft what do you think a near stock zed can pull more than 300 or did you mean more like 500 ?
Not sure m8 don't want to guess/say .... Will only get ppl saying different
Well I hope you reach the magic 250 lol
Who gives a :xxx: what people think I don't care any more there are to many :xxx: out there, who are wannabes or drive around in half maintained sh1t that think they know what there on about,
At least I admit I woundnt have a clue where to start and as long as your happy. :biggrin:
Edited by Car.Mad
Hi Mark, in your porting activitiy are you going to remove the protruding valve guides and head bosses in the ports as I see some modders do? What are your views on the spark plug shrouds in the combustion chamber?
i'm not doing that for 2 reasons really .. Tools .. u need some nifty Press and aligning tools to take out put back and then put in New valve Seats and cut them
and then the other will be just down to Cost of it .. .. really
At least I admit I wouldn't have a clue where to start and as long as your happy. :biggrin:
lol i hear u on that .. but you know what forums are like :)
anyways u want to do a deal on some Audio for body parts ?
