I have 215 45 17 tyres on at the moment and want to know if I could fit Pirelli Asimmetrico 225 45 17 91Y P Zero Tyres without them touching the arches on a standard 90 auto tt lwb import.
Cheers.
Cheers.
Assuming you have a sensible offset wheel then yes is the answer.
Yes, and it should also be noted that 225 is the stock front wheel width with a 7.5" wheel , so you have been running narrower than stock previously.
These are Stern alloys split rim and the rears are running 245 45 17 with no problems if that helps cos I dont know the off set.
