battery
please help needed, I have a problem with my battery going flat if I don't start it every day any ideas what may be draining battery when parked for more than two days.
Have you checked the obvious like interior lights not going off, the boot light staying on for example?
There is a way to test for a drain, with a Multimeter, but someone else will have to tell you how.
Ive not do it before or had this problem but you could try the following:
charging the battery.
fitting it to the car.
Connect a multimeter to the battery showing voltage.
Then systematically remove fuses and check the battery voltage each time you do.
In theory you should see a voltage gain if you come across the circuit with the drain. unfortunately if you find the circuit responsible you will have to track it further to it components but its a start.
