Guess what .......................Engine out again
it never ends for me ..
looks like a may of blown a piston ...
soo its forged time looks like
but gonna be off the rd for a little time and going to
miss some shows looks like :(
any one got a good bottem end with forged parts they want to sell ?
  • Replies 264
  • Views 11.4k
just read a bit on this to catch up cancel off my order as ive got a few K of parts to order in anyway so will get my bearings at same time as i casnt check what sizes i need at the moment.
On your engine though im not sure what has been said already but are you planning on using parts from that fried engine and are they going to be inspected?
all ready beat u to it ..
Crank/cams/valves are good to go
Heads are being skimmed and valves re cut
Block is getting re-bored to 87.5
and Water ways debured
so its having major overhaul
pistons/rods/bearings/bolts/pump
load of other little things
Is the block getting sorted to cure the problem with No. 6 over heating? ie i mean getting the water ways bored out to the rear to pistons?
yeah i'm doing that ... going to de-Bung it and open up the channels
then put some new Freeze plugs back in
if thats what u r talking about ...
I think i get ya otherwise i csn see this same problem occurring again with the drama of the zed lump and the issue of cooling to the rear cylinders which im sure others can back me up on.
It would just be a shame to not get the waterways bored out and then fry another piston after the amount spent on the rebuild
even jz's still have issues here and there i seen some dead ones with same pistons as marks for the same reasons lol
well thats all the AC items out the car ... just left the AC Matrix in .... that will not be a problem will it ?
heavy matrix ... yeah right
your still gonna be slow .. and all ways behind the Red car .... as you know Red is the fast;st colour
lol at you two. like a married couple! how long did it take you to remove the dash mickey? wouldnt mind removing my AC evaporator from mine especially now the heater matrix has gone, but dunno if I can be bothered with the hassle.
Another Q ....
OIL & Filter Would it be wise to go with 1 grade thicker 10w50 ? as i have been using valvoline Sport 10w40
as my local supplier been selling it cheap £10 for 5lt
Plus Oil Filters been using Blueprint Anything better ?
the piston has detonation damage mate,its classic under fuelling not a heat issue,he had 14 afr on full boost.no 6 goes because its last in line for fuel.
Come across this today EP RACING VG30DE CRANKSCRAPER WINDAGE KIT (RACE)
http://epracing.net/zencart/index.php?main_page=product_info&cPath=1&products_id=1
whats this all about ?
Stops oil from floating around in the air in the sump and being wipped up by the crank keeping more oil in the sump and less flying round i have one in my group a engine well worth buying mark
Mark i always use fuchs pros s 10/50 in all my forged engines i build that combined with a genuine nissan filter would be great i would not use a blue point on this engine build personally
ok will order a OEM filter ...
will see what oil hes got in but i been happy with this oil .. hes only selling it cheap due to change of brands supplied
all so what Gear box Oil ... as i just drained it all out want to put some new in .
The reason i use the fuchs pro s is because i used to knopw someone in the oil industry and that really is the only one i ould use millers a second choice amazing what inside information you find out from the plants themselves as to what is a true synthetic oil ;)
been doing some cleaning and painting today .. De oiled/greased
Painted all external items Black and Silver .. the Main Block is going Red to match the plenum
Now i Read somewhere that its wise to Tig/weld the 2 nuts on the counter weight on the crank as these tend to come loose ... what u guys think ?
