Hi,
I really not sure what i can do now ive been trying to source these inserts so i can fit my diff but had no luck so far.
I really dont want to waste money buying new OEM bushes only to use the inserts. Has anyone got any bushes or unused rear subframes that have these inserts in?
Thanks Dan
Hi bud thanks for your reply ive got solid mounts fitted to the subframe i just need the inserts to slide in to my poly diff bushes in the rear subframe.
Pic below
Thanks Dan
Hi Dan,
Have you got the exact dimensions and material spec' etc? I might be able to get them made at work for you.:hammer:
No promises mind, may take a couple of weeks,:whistling: so if you are not in a hurry it's definitely worth a try,
Dave.
Hi Dave i only just seen your reply. Thanks for the nice offer im hoping JeffTT will be saving the day when he finds a good breaker. Thanks Dan
  • 1 month later...
I might have what you need here as just stripped a rear TT frame. I cant Pm on here as not a member but if you want to call its 07593178288, Hopefully mods dont mind this as just trying to help out another zed owner, and please could you remove my number after Gibster has replied.
All cleaned and painted in primer to protect for you mate.
Cant clean the inside got nothing small enough to hand. But all solid.
From here
Thanks so much mate i wasnt expecting you to clean them and primer them for me as well :) I can finally carry on with the fitting of the diff now. 1 step closer to finishing this long drawn out build. Cheers Dan
They hold the diff in place mate. They are in the OEM bushes but have to be removed and re-used when fitting poly bushes.
