silly question which are the "Front Pipe Water Hoses"
I remember there being a detailed labeled picture of the under bonnet but i can't seem to find it now. some nice cheep red ones in zcentre was thinking of buying just to bulk up the order so that i'm not just getting a clutch hose. but the picture doesn't look familiar.
There are 2 small pipes/hoses that connect from the water pipes in front of the cam cover to the block.
images?q=tbn:ANd9GcR-dJ6Urgh6VwRNDe3vX-TWDtf-OlGaU1Rb__tnn6wokT2pXqeK
so not too much of a chew on to change then? don't supose there is a photo of them on the car thats easy to find?
You dont need a photo go open the bonnet look behind the fan. There$ two ali tubes behind them you will see two water pipes, thats the ones in question.
If you change them make sure the mountings on the engine aren't rusty and use a silicone sealant as well when fitting.... If you don't believe me ask Nissan in Coventry !
I was at work at the time and the car was at home. I've ordered em anyway just because they were cheep, probably won't get round to fitting them for an eternity though.
cheers for the help though guys
