Removing goo/mastic from lamps
Hi,
Anyone have any good tips on removing the grey/black goo/mastic that's used to seal lamps etc?
Vijay
All I can think of is heat and a scraper, still going to be horrible tho'.
Would it come off easier if you stuck it in the freezer to harden it, then chip or break it off?
Just a thought.
yeah, heating it only makes it more of a mess... keep it cool and use a plastic/wood scraper (so as not to scratch the surface).
I found that WD40 gets the last bits off really nice.... :)
I used a hair drier a stanley blade and a couple of screw drivers to lever up, mine was grey sealer.
I've ended up sticking the bits in the freezer then using a stanley knife to cut as much away as possible. Then use petrol/thinners/tar remover/wd40 to remove what's left. Only thing I'm worried about is damaging the lenses :(
Hi,
Vijay
I'm sure I've posted this before but I'll post it again
BLUE PAINT BRUSH CLEANER..!
available from all DIY stores, it dissolves the mastic and cleans it completely off. :wink:
Yep, thats it. I went through the shelves in my garage trying everything to remove the stuff, then found that stuff works a treat. probably still best to scrape as much of first then use that to get the last off.
and it will clean it off your hands afterwards. :clap:
Croeso, thank you, much better than petrol or white spirit :)
