radiator expantion tank?
Can someone please advise me, is the radiator expantion tank on the left side when standing in front of the car? Sorry if a silly question but its a JDM and I cant read japanese :blushing:
When facing the front of the zed, it is located under the passneger front wheel arch, you will need to remove the arch liner, usually screws or 10mm bolts, to access.
Without removing the wheel, just need to turn full lock, you will be able to see it, but easier to work on with wheel off.
Stu
first pic (drivers side) with clear top in the corner is screenwash, the middle pic with black lid is power steering and the other (passenger side) with the yellow lid is the expansion mate
cheers guys, glad I asked before sticking antifreeze in the power steering! That would have been, erm intresting! not
yup otherwise it will expand in there overflow an dwee over teh rod causing descress to the owner thinking its blown up inside.... been there done that .
