Fitted the 'Bycas' Today.....
Well the good news is it fits!-this is the kit, I was worried the arms looked weedy in the ad but they are 14mm so happy with that!
Just a quick measure to set up the arms when fitted,
Then took off the old rack,valve,Solenoid etc.
The bar fitted,this needed one hole elongated about a mm to fit but that's the only issue I had.
Next job was to remove the outer ball joints,this is how I do them,takes 10 mins each.
The 'Top-hat' alloy inserts then fitted along with the arms,
Adjusted to the measurements taken and I have a tight arse!:ohmy:
So all in all I'm happy with the Quality,fit etc.Time will tell if it's up to the job!
Thought I would Waxoyl the sills whilst on the ramp,drilled a couple of holes into the sill,pushed a 5' long pipe down and filled em' LOL!-a couple of grommets to bung the holes and undersealed over!
Got home and fitted new injector plugs,what a PITA job!-these are the plugs I used,need a bit of modding but at £3 each was a cheap alternative! and they won't fall off!
Tomorrow I fit the new PTU and hope that's the misfire sorted!:sweatdrop:
  • Replies 34
  • Views 1.8k
nice ball joint removal, think thats what I'll do lol. :thumbup1:
That's the idea,plus the hicas pipes on mine were leaking so 2 birds and all that!:wink:
always intresting reads and pics from daz...great work matey:thumbup:
Right!-fitted the new PTU (cheers Daz) and moved it under the nose panel,also renewed ECT plug and rewired gauge sender.
Idle is now a bit high but she runs sweet!:chinese:
No pics Today as I couldn't be arsed!:yawn:
Looking good mate. This is one of the jobs on my " to do " list that's about 3 feet long LOL. Did you pay £199 for it and why did you choose this one over the Drift works one ?
Alright ugly!:biggrin:-no,I paid £194 for it and chose it because of the solid middle bar.The DW one has 2 seperate brackets,which are probably good enough-just not for me!:chinese:
  • 2 years later...
sorry to dragthe thread up but what injector plugs were they at £3 each and what was the mod to them?
There called 'junior timer' connectors mate, Durite do them.the mod is dremelling out a notch that the OE ones have and these don't.
Work fine!:cool3:
they was the ones i used ... i cut the lug of the injector to make them fit as the locating groove was off center
  • 10 months later...
Tried to fit my eliminator kit again today, for the life of me I can't get the ball joint out!!!
Mark derby said to cut it like in pic 5 but how easy does it come out once this is done?
Don't want to cut it if it is just as difficult to remove as I can't just leave the job half done (daily driver).
Any info would be greatly received.
Should be able to just tap it out mate :) hole punch or crap screwdriver and whacking stick :)
:lol::lol::lol:
Never done them then :lol::lol:
