In memory of Mandy
Plenum Bypass Help
Anybody done a plenum water bypass before and fancy helping me with mine?? I have water leaking right onto No3 coilpack and shorting it out causing a missfire, and its really pissing me off now haha.
Theres a bacon sarny and as much tea as you can drink in it for anyone willing to help :p
thanks for the link, very helpfull :)
but i would still appreciate some help. I am very unfamiliar with the engine and while i have decent mechanical skill, i wouldnt like to tackle such a big job on my own. Also it gets very lonely working on a car on your own, so the company would be nice too :p :p
Its TT. I've not got the plenum off yet, but i have another plenum to go on which i've painted red, so i'm going to use that guide you linked to remove the water pipes from that before i remove the old plenum :)
if your doing a water bypass then you mights as well remove your egr valve to seeing as your taking the plenium off bud kill 2 birds with one stone.
also mods I think this tread would be move suited if moved to the help and advise section so others can maybe help out to :)
Edited by Ceejay
Ahhh, ok, noob question. What is the egr valve and what does removing it do? Was going to remove my AIV valve while i had the plenum off
Good call,they are under the wings mate:wink:
ahhh yes, i just read up on it. How do you bypass that? is it as simple as just connecting the pipes that are left?
TwinTurbo.net do a full wright up on the removal mate then all you need to do is make a blanking plate to put onto the plenium and a plug for the manifold using the old nut to secure it. Hope this helps fella
