rear lower ball joints
can anybody recommend where to get these from and a rough idea of how much they are . ive heard they have to be pressed into place , can this be done on the car or is it a strip down job
iirc they are not available on their own :( You have to replace the entire wishbone.
JeffTT would know the answer.....
.....and as for new parts; you can't go wrong with Mike Feeney at MJP!
Richard:cool3:
Last time I asked Mike they were £249 less vat each :helpsmilie:
A second hand one should only be about £25 or so and they don't wear out that easily.
ar these the ones you grind the front off heat up and punch out the wrong way?
No, that's the HICAS outer ones mate.
its the circular one taht sits between the wishbone and hub assembly? correct? theres a 23mm nut on there i believe which try as i might i could not get leverage on from any angle. whole new corner from jeff is cheap as it it
ahh thats right, sorry im of no help then lol
That bolt is a bugger to get too. I ended up drilling a hole into it and then split it with a cold chisel.
I should think Jeff will be able to sort you out with one. That's who I got mine from :)
Send Mike at MJP a message, you might be able to get a ball joint replacement and press it out and new one press in. You now can for the front lower ball joint and they are about £35 each - they might be the same.
It would be advisable to remove the arm to remove/refit ball joint and while your at it replace the 2 bushes at the subframe side.
Edited by turbocraigy
Send Mike at MJP a message, you can get a ball joint replacement and yes it can be pressed out and new one pressed in. They are about £35 each.
It was Mike that told me they aren't available separately from the wishbone :confused1:
Oops! You replied while I was editing my message. I mean't MIGHT. It wasn't long ago that the ball joint for the front wasn't available on its own, now it is.
If Andy does end up buying complete wishbones, I suggest he tries CZP (US) - much cheaper.
lol. You could be right mate, I spoke to him about it in the spring. So it may well be available on it's own now. Would make sense.
