Engine tech mystery
So here we have a technical fault that was dealt with in the workshop recently, thought it may be interesting to see what you guys would make of it and see if maybe we have a budding technician or a right good guesser among the membership!! I can tell you this is a weird fault with a surprising conclusion, read it all through before making any conclusions.
So let start with some background first, a standard non turbo running well with no major issues that developed a small water leak, the owner with some tech help from Jamie here and some pipes removed the plenum and replaced the offending pipes, the work seem to go well but once all back together the first start up was less successful.
The owner went over his work and with the exception of switching the coil pack connections on number 4 and 6 cylinder could find nothing to cause the non starting.
However with a fresh battery charge and some long starter motor action eventually it started, this is where we gave some further advice on checking vacuum pipe connections, electrical connections etc. at this point it was realised the det sensor and near side variable valve timing solenoid connectors were the wrong way around and so with these correctly plugged in the owner happy to do a road test.
This is where it all went wrong! the performance was terrible with a huge performance loss, lethargic acceleration coupled with a low tickover, and a sheer reluctance to rev when stationary and in neutral.
The next stop for the owner was a very slow drive to the workshop for us to take a look.
So as mentioned this was very poorly running zed, as we knew the plenum had been off and the potential for air leaks after we went straight for a leak check. In all fairness there was a couple of small leaks and one major one where an air pipe had been left disconnected under the plenum on the n/side.
Further checks of the smaller vacuum pipes found the egr valve incorrectly connected and so this was sorted and confidently the engine was started, but argh!!! exactly the same! no improvement at all, static revving the engine just produced this weird really slow build in engine revs whether the throttle was opened slowly or wide open, a seriously muffled sound from the exhaust.
So to recap, the engine has serious performance issues, but will not rev, now we know there is no air leaks, no pipe work errors, no misfires on odd smelly exhaust was no surprise because clearly something's no right but either way time for the ConZult.
ConZult screen One
So here is the first screen shot, for the uninitiated the there is a fair bit of info on it that is important and some not to worry about but in short there is a faulty O2 sensor a good timing reading ( confirmed with a timing gun) a high iavc ( idle control ) valve reading but the temp is only 67C so again not to worry about yet, BUT take a look at the injection pulse 4.03 ms !!! this is practically double what it should be, but with a an A/F reading of 108 % it could be easy to miss it as excessive enrichment. High injection pulse can be cause by air leaks due to the readings at the air flow meter been corrupted by the leaks or and very common a failed afm can give poor or corrupted readings that are still in its total range so hence no fault code error readings.
ConZult screen Two
So trying to keep it brief the next screen shot is some time on, lots of things have been checked again and again including timing, air leaks , vacuum pipes, throttle balance tps o2 sensors disconnected and reconnected, spark plugs checked cambelt timing checked all with no improvement.
So this particular screen shot shows an amazingly odd set of readings if you look at the part throttle tps reading against the actual engine revs of 3,700, this again was a hard, slow and lethargic engine that was slow to pick up. The injection pulse of 12.5ms is worrying so was the awful smell coming from the exhaust serious incomplete combustion, luckily we have a very well ventilated workshop!!
A split second after this screen shot without any more throttle opening the engine revs to over 6k very suddenly, releasing the throttle the revs dropped to idle, each time we tried the it the same thing happened. Now this is all very odd but even more so when you consider that we had the air flow meter disconnected at this stage!!!! yes that's right an engine revving at 3,700 and upwards with the air flow meter disconnected.
AFM Disconnected
So now we have moved up a gear with an engine that does not respond to the expected fault finding procedures as with the afm disconnected the engine should not rev pass 2,500rpm, oh and no fault code appeared in the ecu memory.
Ok guys so what do you think? just a little bit of fun, I doubt anyone would guess the exact cause of the fault because it was a bit bizzare in a simple way but had big repercussions.
So to recap.
Poor engine performance
Very slow resonding revs
Odd smell to exhaust
Swapped checked
AFM
ECU
TPS
Timing checked
Cambelt checked
Leak check
Abilty to rev to 6k with out an air flow meter
Jeff TT
  • Replies 94
  • Views 3.3k
jeff has gone, he is now laughing is head off somewhere and trying to contain the tears running down his cheeks lol
lol oops sorry wrong part, idle adjust plug, plugged into the O2 sensor connector
Nope.... different plugs.
Jeff
I'm thinking something stuck up the exhaust too.
:no:
Jeff
Back again was catching up with the Xfactor.........yes I know :tongue_smilie:
Jeff
Revving over 2.5k with MAF unplugged? I'm still thinking bad chip/ECU issue...
Steve :)
Well not a bad chip or bad ecu ( was swapped out anyway) but.................:whistling:
Jeff
i reckon he hasnt fixed it and looking for solutions
BUSTED!!
Jeff
Its probably something so simple in the end that we are all barking up the wrong tree and when Jeff puts us out of our misery, there will be a massive FFS :lol::lol:
Top marks !!!!
Jeff
youve been over the connections so cant be as simple as mixed O2 one up with boost soloniod connector or egr soloniod
No, well, erm, :whistling:
Jeff
pin for lambda sensor in ecu connector came out
nope! ......... still have the over revving with afm disconnected!!
Jeff
hold on, over revving on the AFM, is this a red herring? or is there something simple like a short in the AFM wiring causing it give a faulty reading and the ECU to believe there is a AFM connected still
Cool thinking there matey, in fact I was on the same train of thought especially as there was no fault code, however when unplugged with the engine running the engie cut out and had to be restarted so something was changing when it was unplugged??
Jeff
Is the ecu plugged in ?
:oops: never thought of that.....:biggrin:
Jeff
Jeff
lol Jeff, that's it throw a curve ball in there. Only thing that would change when unplugged would be voltage id imagine (correct me if im well off) hence the engine cutting out. but with it unplugged then started again, the voltage wouldn't change as its already unplugged. blown fuse?
AFM plug had been replaced and wired up incorrectly?
No, it was all ok before the plenum pull.
Jeff
All fuses ok.
Jeff
