metal work wise im filling all holes, removed battery tray, smoothed strut tops/inner arches/chassis rails.
basically the only thing i want in the engine bay is the engine and brake servo.
has anyone done anything with the loom so it is simplified
was thinking of relocating ptu to under nose (should help keep it cooler)
temp sensor wires to come from under throttle cover
reroute the loom that runs along the sides of the engine.
has anyone relocated the small fuse box near the brake servo?
my aim is to make things as simple as possible/hide wires and make access alot better. obviously im going to have to cut/extend some wires but that will be good as i will basically make a new loom.
Just wondered if anyone has done the full works
so far i have
relocated battery to the boot
deleted aivs,egr, carbon canister and hicas
relocated fuse box to under nose pannel
going to relocate fuel filter to under wing
what trunking looks best?
