JaiKai Black Zed Project
Just bought a 1996 Twin T Auto - Series 4 in Black.
Its currently got a cloth interior and a badly fitted veilside kit which I plan
to remove and sell on shortly.
Using my other 1991 NA i'm planning as using that as a donor car and swap
over all the goodies i like on that.
Let the games begin
  • Replies 108
  • Views 5.9k
Getting a respray next month - which colour should i go for ? 29 members have voted
  1. 1. Getting a respray next month - which colour should i go for ?
    • Metalic Purple
      17%
    • Black
      68%
    • Silver
      6%
    • None of the above
      6%
Mine was done the same way lee and got the same results.
It put me in a downer tbh. 90% of the people love it but i know its there if you know what i mean.
I will get mine redone in a year or so, or maybe not with a little one lol!!!!!
Looks super in the pics :yes:
  • 1 month later...
Time for a project update !!
Took a brave pill today and decided to cut a whopping big hole in my dash.
With good reason of course as I wanted to fit my new guages, new as in never been
used but i've actually had them for over 5 months now along with the dash mount
holder to put them all in.
Following a cutout template i masked off the area that need to be cut and took out my
trusty craft knife {more like a surgical knife} and cut the top layer of dash away; Then
you have to scrape all the foam off untill your left with the last bit which is just another
thin layer of plastic. Dremel in hand i slowly cut round the template again making a hell
of a mess in the process.
I quick test fit then i took the hoover out and sucked up all the shrapnel that was just
created by the dremel - messy stuff
Last pic shows the template removed and dash hoovered up a bit.
After i do some guage tests and wire up a power point / switch i'll get some clamps
and make them a perminant fixture.
Wired up the senders to my guages today then trial fitted them to see if everything worked.
So far Oil Temp, Volt, Water Temp work in the bottom din socket.
I've got Oil Presure, Air Fuel, Boost in the top dash mount slots but so far only the boost
guage works, i've run the cable for the oil but the sender for it is still on my NA so soon as
theres some good weather i'll try swap them over.
Lastly is the air fuel guage which needs to be wired into the ecu, i'm likely going to put a
switch in to turn the whole lot off and a switch to swap between left and right side readings
on the airfuel guage.
Still need to properly glue the top guage mount down but gonna leave that untill i know that
i can get the other top guages workin just incase.
Heres a nice shot of what they look like at night followed by one with the flash on.
