JaiKai Black Zed Project
Just bought a 1996 Twin T Auto - Series 4 in Black.
Its currently got a cloth interior and a badly fitted veilside kit which I plan
to remove and sell on shortly.
Using my other 1991 NA i'm planning as using that as a donor car and swap
over all the goodies i like on that.
Let the games begin
  • Replies 108
  • Views 7.6k
Getting a respray next month - which colour should i go for ? 29 members have voted
  1. 1. Getting a respray next month - which colour should i go for ?
    • Metalic Purple
      17%
    • Black
      68%
    • Silver
      6%
    • None of the above
      6%
Having the install in the boot had its advantages too, i'm going to slot the alarm box &
the jumble of wires it comes with in the cavity next to the antenna motor, plenty of room !
First off I bought a servo to unlock the boot which you can see in the pick below, its
not fully fitted yet as i'm missing a relay to activate it from the alarm but I should have
that in the post by tuesday.
I also tapped into the indicator lights from the back rather than atacking the cables in
the control pods which seems to happen on most alarm installs i've seen.
Lastly before it got too dark I snapped a pic of the freshly built today interior !
Thats the zed drivable again and I took her for a quick spin round the block.
Just me stereo and guages to do next, only 3 days before the trip to JAE so better get
cracking.
OK Shrek,
Finger pulled swiftly and the zeds drivable again!, Yehhh Haaa
JAE 2010 here I come !!!
:cool2:
Alrighty,
Just nipped into see the painter called archie and my two bumpers are prep'd and should be
done for tommorow.
Hopefully the weather will be good tommorrow as i've got a day off to fit them.
It is my wedding anniversary on thursday but i'm sure she will let me do it !
fingers crossed for good weather and a wife thats in a good mood.
By the time I finally fitted the back bumper it was pitch black outside so
these are the best shots of the bumper back on.
The shine of the new bumber really shows so i'm going to have to give the
car a good hose down and wash tommorow so that is doesn't look as bad.
Too late and dark to start on the front so will leave that for now :
Fantastic shine on the kit mate. Black is a bugger to match up. Its near impossible. Ive had black cars for 7 years and never managed to match it up lol!!
Lee, been watching this thread as it progresses. you have done what im planning on mine. i have the rear bumper of my spare zed. and saving for the 99 front and spolier. what colour black have you gone, is it KH3 or something else
must see pics of the 99 front and spoiler when its done.
Black zeds are so sexy...................:thumbup::thumbup:
Front bumper time !
The old veilside bumper came off fairly easy however I think its a scrapper as
the bottom part is missing and theres a few splits at each end.
After the bumper was off I had a wee look at the cabling situation for the front
fogs and side lights, it seems the original loom was butchered to fit on the other
bumper, also i've got a fault with the side lights as at the moment they wont
power up. I originally thought this was because of the bad wiring but after I put
everying back on to test they still wont work.
Having spare plugs I decided to do a proper patch job and I resoldered and heat
shrunk some tubing over the cables to protect them.
I see that there is three cables going into the side lights and front fogs, can any
body tell me what the dual purpose is for ?
I decided to carry on for now and refit the lamp holders.
then pop the bumper back on.
It started to pour down again at this point so i never managed to refit the front fogs
and side lights, they dont seem to work anyways.
What does work is a side light bulb which is part of the front fogs and this turns on when
the side lights are suppose to be on. Other than that I have no real side lights or fogs.
I've checked all the fuses and they all seem to be fine, could it be a faulty relay ?
Yes, its KH3, but it looks hell of a more shiny than the rest of the car.
Righty O !
Its cluster time, today i stripped out my old silver zeds indiglow dials and put them in
the new black zed, so why did i just not change the full cluster over I hear you say !
Well, Nissan decided to change the cluster in the series 4 which the black z is so the
cluster from the series two wont fit, there physically different on the back and inside.
Heres a shot of the series 2 cluster.
And here is the series 4 cluster.
Spot the differances ?
The indiglow dials were stuck down with double sided tape to the originals so easiest
way i could think to get them apart was running them under boiling water for a few
minutes which worked great.
Below is the series 4 cluster with the indiglow fitted, i had to mod the oil guage to get it
all to fit properly but they do fit eventually, i just trimmed down the overlay very carefully
as not to damage to out circuit on them which powers them up.
Heres the front part re attached before I put the case back on - looking good so far !
And heres with the front put on too
When fitting these back into the car I actually had to take the face off again then try
to calibrate the dials again - luckily i've got a consult cable to see the actual guage
readouts from the ecu.
Great work Lee. I'm watching you progress with interest mate. :cool3::cool3:
Front bumper time !
Hi Lee, the three wires in the plug are for the side light and fog feed, they share the same ground, black wire and the 2 stripe wires are the feeds. You may already know this lol, but the sidelights should come on also when you depress the fog switch.
Dropped off both of my zeds tonight to the garage of my mate duncan !
Work to be done while they are both there is :
swap exhausts
swap over water pipes and install new temp stat
swap the nice shiny plennum
swap over anything else shiny - i luv the shiny stuff
Not sure how long they will be both there so looks like i'm zedless for a while.
I couldn't get time off so my brothers helping out do the work - i'll get him to
update us all with the work being done - just hope hes an ok shot with a camera.
I'll post pics up as the come in.
