Replacement 3G big brake kit rotors
I put a 3G big brake kit conversion on my car a while back. I now need new rotors (or full disks) for them. I can't seem to get any response from 3G and I don't know if they're still trading. Does anyone know where I could get some from or whether any other disks will fit this kit? I'm reluctant to purchase a completely different big brake kit from another manufacturer.
Ta
Their website is still about, Just looked at it. I take it the 3g big brake kit uses afermarket calipers? Or does it still use the standard caliper?
Found these on ebay - they will most likely fit also appear to be from 3g themselves!
http://cgi.ebay.co.uk/Skyline-R34-GTT-310mm-TWO-PIECE-Brake-Discs-FRONT-/320464262966?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4a9d289736
It uses the standard calipers but uses a pair of brackets to re-position them further out.
Okay, the disks above should do the trick, or at least give you a way of contacting 3G
Well they'd fit if the width of the friction area of the R34's disks are exactly the same as the standard 300ZX pads and the offset from the hub face to the centre of the disk axis is the same. Is this the case? The 3G kit uses the standard Z calipers.
