Would this Apexi fit our cars?
  • Replies 26
  • Views 1.7k
no idea...but thats more expensive than the proper 300zx fitment Apexi!
Best person to ask is Dan from DTA had a convo about this a while back
Ie: universal over z32 fit
Is it?
I thought they were well over £100 from DTA.
correct there a bit over a hundred now at dta to my knowledge, there is a recent thread around listing price etc
ah sorry, didnt realise they had gone up. They were about £80 before.
i thought there was a world wide shortage on genuine Apexi's
Yeah i heard the same Bri! ....supply and demand issue perhaps?
Yes, there's a major supply problem (worldwide) and as such prices have gone up astronomically. Rrp used to be £65 however now it's £110 ... :-(
Anyway, I've got access to very limited stock at one of my suppliers (
Regards,
Is there any benefit of the apexi over other filters? I have a gigantic hks filter on mine but no idea how long it's been on and could possibly do with being cleaned/replaced
Never heard a bad report on an apexi, it's also a dry type filter better for our maff i heard?
not sure on other makes i eased away from foam type filters though but know many that are very pleased with them :)
Yup, better filtration and airflow over any other manufacturer (proven).
I went for an A'pexi.
thats the main reason I wasnted one, to do away with the oil type filters.
Managed to get 1 from Dan @ DTA, should be here in a couple of days :thumbup:
Excellent will be easy fit then :D
hmmmmmmm looks like that will be getting changed next then, whats the crack with these twin filter thingymajigs aswell? guessing over a certain power you need them?
you would not really see the benefit performance wise i guess without other supportinmg mods.
I have thought about this though but would like my own splitter made that faces the cone's forward instead of back.
I found that Horsham Developments was quite cheap. As they specialise in 200sx's the filter for the z32 MAF is considerably cheaper than for their own...
http://www.h-dev.co.uk/index.php?cPath=78_169_409_419_426&osCsid=533f1830d47091da8acf5693a3edc8a0
Yes, I tried them and they haven't got any in stock when I checked yesterday. Also, this is just for the universal filter head, the gasket and fixing bolts are not included.
did not know it was only universal flange needed then? :( are all your units z32 fit danny?
When I purchased from them it was the exact fitment for the Z32 maf, no adaptor or flange required, it came with the gaskets and bolts and it just bolted straight on :s
Yes, our Apexi kits are specific to the Z32. The issue with the universal flange is that they don't line up nicely with our Z32 MAF design. I very often see Apexi kits advertised as being for the Z32 and then pictured with either the 350Z or S14 MAF plate/gasket. Neither of these work well on our Z32's.
@ Rigs, that may have been from old stock then ... guess you were lucky.
Regards,
Depends on whos testing it, other tests have had some interesting results :)
http://www.australianauto.com.au/HTML/Images/Air%20Filter%20Shoot%20Out.pdf
I tried to get a couple of the Austrailian cheapo's to try, but ended up with the AEM Dryflows. Flow aint too much of an issue as I have a twin filter set up
