wire oh wire?
on the coil packs or what you call them the two little wires to each pack , one is yellow and black and the other diff colour but thinner my question is does the thicker wire always go to the the front end of car or rear. ?
sorry it must be the two wires going to the injectors,help needed im nearly there.:no:
if they are the injector connectors then im sure the connectors can only go onto the injector itself one way as it has a groove in the connector so it cant be fitted the wrong way round,
or are you attempting to change the connectors and need to know which way they need connecting
thanks and sorted it now,what it was they had no plugs on the wires just little cable made up things for some reason?
