- Replies 63
- Views 3.8k
- Created
- Last Reply
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Ok i thought i would start a new thread as my recirc thread has become a bit long.
Right basically i cant boost past 17-18psi it will hit 17-18psi then drop down to 14 or so..... its not the ebc as ive had the actuator pipes off and it still wont boost past the above pressure. fyi i dont have the stock actuator solenoids anymore.
the ebc does make a difference, if set to 0% it will boost a steady 10-11 psi
on 100% of course it will on boost to 17to18psi depending on gear... anyway this is irrelevant seen as ive had the actuator pipes off.
i have ditched the recircs hoping they were leaking, I fitted a single Bov which dumps nicely with no leaks.... This has not cured the problem.
The car idles nicely so im pretty sure there are no boost leaks(i have tested for these!) these would be pretty obvious if they were the problem. Im going to do another boost leak test 2mow and test it at 18 psi to see what happens.
Can anyone suggest any possible causes or tests i could perform to resolve this its getting annoying now and holding me back from my remap......
Thanks in advance.....
Edited by j1mmytt
