After searching the 'net, I found a couple suppliers had them in stock. First being Torquen - albeit at over ยฃ600 for a pair for either cast iron or aluminium.. Then I found some fully rebuilt aluminium ones (the correct fitting for a TT) at less than half that, which got me thinking. Cast iron vs aluminium....??
Opinions please - good or bad๐
RichardS ·
Hi guys.
As i am someone who buys and sells his cars quite often,ahem,
i've had a couple of good quotes to cover ANY vehicle i want to drive,
including the 3.1tonne van + the bikes.
Any good guys anyone can recommend ?
