boost controller fitting
hi,i know this has been covered before but can anyone post a diagram of were i need to connect my electronic boost controller.i`m having trouble trying to work it out from previous threads:confused: any help will be very much appreciated thanks milly
now if you was a subscribed member i could pm you the instructions i used!:tongue: if you put up a email address i will try dig them out and send them.
dan.:)
hi,thanks millyntrudie@aol.com cheers milly
e-mailed :)
you just connect the wastegate pipes to the boost controller, instead of the intercooler pipes at the front.
then where the wastegate pipes were originally connected (intercooler pipes at the front) you just join them together, then put a T piece in and also run to the boost controller
