before i begin, must thank the forum! without it wouldnt have resoved it.
certain few, Anthony D, Jeff TT, Legrath, loads more cant remember!
anyway, the problem was, did an engine swap, my TT into a NA. used the NA loom, used my TT ECU, TT pump, NA pump controller, NA prop/diff/subframe etc etc.
after the swap, engine didnt start. after the car went on diagnostics, there were no negative signals getting to the injectors. but there was posotive.
i had cut off the corroded connectors on the injectors, and made my own, with speaker spades. still woudnt work.
the neg signals come from the ECU. Tested the ECU on anthony Ds Single Turbo Z :bow: it worked.
put a noid light on the connectors of the loom (wire) flashed, so the signal was getting that far.
Ohm tested the injecrtors themselves direct, like this....
they were all in spec :)
then tested the end of my new injector conenctors where the wire meets the loom (not the spade end on the terminals)
the Ohm reading was about 0.02. :shock:
so i got some of these, 7 quid each,
even after putting these on, it takes a few times for them to sit correctly, as you need to ohm test the end of them after connected.
spun the CAS by hand to test each one was clicking, then fired it up :)
thanks for help :)
