Wheel offsets
Hi all,
Yet another wheel question. Will a 9.5j et20 fit on the rear of the Zed as i have the chance on a deal if they do.
Not a problem if i have to roll the arches;)
Dan
Anything will fit if you roll the arches. You'll have to roll them really far out fitting them with that offset.
Mine's 9.5 with a 35mm offset and they are on the limit. You'll have to pull them out at least 15mm to get them under it and that's quite a bit of rolling.
The max your gonna get with rolled arches is a 265 et20 on the rear mate :)
with flaring this would probably allow for an extra 10mm
Some extra negative camber would help. You can dial a little extra over stock to improve handling anyway.
What camber are you running si ?
So it is possible! Where or how would i be able to get the rolling done?
I like the way the wheel sits on your car funkysi. Will the et20 sit outside the arch do you think.
I will be getting some adjustable camber arms aswell.
Cheers for your help guys
I can't remember, it's the higher end of the stock spec iirc. I don't like loads of negative camber, A: it looks like the car's suspension is shagged and B: it'll wear the insides of the tyres out at a huge rate.
i used to work for arch enemy, and have the tools and stuff here for doing it :)
usually rent it out, but im willing to swap parts for the zed, for the equipment and instructions fto roll your arches :)
Please remember that selling/trading on this forum is a priviledge you enjoy when you are a Subscribed Member. Registered Users are NOT permitted to sell/trade on here!
Thank You.
its no prob mate, im hopefully subscribing tomorrow, just waiting on pyapal making the 2 deposits, then il send the subscription fee :)
Excellent :D :bow:
You won't regret it my friend :)
ive intended to join for a while, i decided to hold back as some people were being very pushy about it, and i dont take kindly to that
What can i say matey, its a sore subject for some, but lets not get into that :)
just get your money out or else
joking;)
i have neg 2 on the rear on my z and tyres wear even!
